  • Kelly
    May 17, 2005 at 4:19 pm
    From LAFCPUG meeting with the program developers, a Q & A session:
    Q.) I’m getting this color shift (a kind of flash) in my transitions when using DVCPro HD. Has this been addressed?
    A. Yes.
    Lots of good info, check it out:
    https://www.lafcpug.org/feature_fcp5_stp.html
    TV is called a medium, because it is neither rare, nor well done (He..he…)
  • Greg Day
    May 17, 2005 at 4:34 pm
    So a PCI firewire card is in our future to solve this so that we can capture straight to the LaCie drive.
    I think the TC breaks are a function of not enough bandwidth on the firewire bus on the g5, as I haven’t experienced them at all going to the xserve.
    I’m using the LaCie FW800 PCI card in my G5 to connect my BDE. The 1200A was running through the onboard FW400 port. I was still getting the timecode break issue, so I don’t know that the card will solve the problem.
    But I do think you’re probably right about the bandwith being part of the problem since the “breaks” would usually occur on capturing longer clips (2-3 minutes or longer). I wish I would’ve taken better notes to see if there was a pattern though, since it certainly wasn’t all long clips that had the problem. Again, hoping that they’re not actual TC breaks!
    g
    Dog Day Editing
    Creative Editorial & Directing Services
    Rose City
  • Walter Biscardi
    May 17, 2005 at 5:31 pm
    [Craig] “My only beef with this workflow is that the deck control is so sloppy through firewire, as compared to 422”
    Deck control is a separate entity than Capture settings so you can set deck control to RS-422 and still capture via Firewire.
    [Craig] “We normally capture to an XServe raid, but recently tried capturing to a LaCie Extreme Big Disk, and encountered all these phantom time code breaks you spoke of. I found that capturing to the raid and then transferring to the LaCie solved this problem”
    That’s interesting because I’m getting the breaks whether I go to Firewire 800 drives or my Medea FCR2X Fibrechannel array.
    Walter Biscardi, Jr.
    Creative Genius, Biscardi Creative Media
    Now in Production, “The Rough Cut,” https://www.theroughcutmovie.com
  • Sean Davison
    May 17, 2005 at 9:02 pm
    one last question!!!!! Does it play HD Dv a la Sony Z1E?
    If it does I’ve made my mind up!
  • Sean Davison
    May 17, 2005 at 9:03 pm
  • Walter Biscardi
    May 17, 2005 at 9:27 pm
    [Sean Davison]
    one last question!!!!! Does it play HD Dv a la Sony Z1E?”
    Absolutely not and it never will, thank goodness. HDV is not nearly as good an image as DVCPro HD. At least in my opinion.
  • Sean Davison
    May 23, 2005 at 8:43 pm
    If I use the AJ 1200 HD and digitise and edit using the DVC proHD Codec ( Via Firewire)
    What will play out of the SDI Bob of My Cinewave card (which still seems to work with Tiger!!!?) Does the HD Signal only play out of Firewire?
Page 2 of 2
