Activity Forums Apple Final Cut Pro Legacy DVC-PRO 50 in FCP Capture card or not?
  • DVC-PRO 50 in FCP Capture card or not?
    Posted by Al on September 15, 2005 at 11:06 pm
    Hello
    I have a question about a shoot I’m preparing that will be edited in FCP.
    I’m shooting with a Panasonic SDX-900 camera. This camera is DVCPRO 50, and apparently can record in 12bit.
    I’m wondering what is the best way to input the footage in my computer. If I go the firewire way, will I maintain the 12bit?
    If I go via a decklink card, uncompressed, it will be 10 bit won’t it?
    I’m mostly concerned because this is a greenscreen only shoot, and I need to preserve a maximum resolution all the way.
    Alex
    Al replied 21 years ago 4 Members · 5 Replies
  • Walter Biscardi
    September 16, 2005 at 2:32 am
    For greenscreen you’re going to have fun either way with a compressed format. You better have plenty of light on the screen, plenty of separation of your talent from the screen and hopefully not a lot of movement in the frame.
    Here we work with DVCPro HD and I simply work with Firewire and the DVCPro HD codec through the entire process, even for greenscreen work. I don’t see a difference between capturing as uncompressed HD and DVCPro HD when working with greenscreen.
    Walter Biscardi, Jr.
    Creative Genius, Biscardi Creative Media
    Now in Production, “The Rough Cut,” https://www.theroughcutmovie.com
    Now editing “Good Eats” in HD for the Food Network
  • Jerry Hofmann
    September 16, 2005 at 3:31 am
    Compare the two and post back. You’ll be fine if you light it right, and either way should work
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
  • Tony
    September 16, 2005 at 5:45 am
    Alex,
    Someone how you got the technical spec of dvcpro 50 wrong. The recorder does not record in 12 bit it is only capable of 8 bits.
    The 12 bit you are referring to is the camera head processing not the vtr. So regardless of how you capture the original footage it will always be 8 bit.
    However if you work in a 10 bit uncompressed sequence you will have an advantage when dealing with color correction.
    Tony Salgado
  • Al
    September 16, 2005 at 6:42 am
    Thanks to all for the replies.
    The part that got me scratching my head was the 12bit. I didn’t see how this was possible.
    So I guess I’ll be comparing the two captures and see if there is any difference when I pull my key….
    Thanks again
    Alex
  • Al
    September 19, 2005 at 5:59 pm
    I have another question. I just tested importing footage into FCP from the AJ-SD930 deck. In FCP it all looks good, and shows up as a 720×576 widescreen shot.
    However when I bring into AE, I get a very different result that what I get in FCP. First of all the image looks squashed vertically, even though the PAR is 16/9, and second it looks a bit crunchy.
    What could be causing this?
    Does FCP have some kind of way to read this footage that AE doesen’t?
    Alex
