Activity Forums Avid Media Composer DV25 Project exporting as 324×243
  • DV25 Project exporting as 324×243
    Posted by Jbarry5503 on March 20, 2007 at 12:02 pm
    We have a project that has been edited using an Adrenaline with source material captured at DV25 411. When we go to export a quicktime reference file we are only able to export a 324×243 size video.
    Can anyone help? Please!!!
    Julie
    Julie
    Zaniac Media
    Michael Hancock replied 19 years, 6 months ago 2 Members · 1 Reply
  • Michael Hancock
    March 20, 2007 at 1:10 pm
    Are you sure you’re exporting a quicktime reference and not a standalone quicktime? The export should be almost instantaneous.
    Check your quicktime reference settings to be sure someone didn’t change them to a standalone quicktime setting (instead of making a seperate Quicktime setting). It happens here a lot. When you export a Quicktime Reference you should only be able to choose Square, 4:3 non-square, 16:9 non-square for your frame size (I think–not in front of the system). When you export a Quicktime you can customize the frame size–Qtime Ref, you can’t.
    Michael.
