Activity › Forums › Apple Final Cut Pro Legacy › DV25 footage in FCP 5 “freezing” on XServe RAID
  • DV25 footage in FCP 5 “freezing” on XServe RAID
    Posted by Aaron D hose on August 9, 2006 at 3:48 pm
    We just installed two brand-new Apple Xserve RAID’s to run with our two Powermac G5 dual 2.5 Ghz machines (OS 10.4.7). However, both machines are having issues with “video freezing” while playing back DV25 footage in FCP 5 (ver. 5.04). Apparently, this happens on the capture end, since when we copy the media elsewhere and reconnect, the freezes remain. But new, fresh recaptures onto other drives remove the freeze, so we know it’s an XServe Raid issue.
    Anyone ever encounter this problem?
    thx in advance.
    Aaron D hose replied 20 years, 1 month ago 3 Members · 4 Replies
  • Steve Connor
    August 9, 2006 at 5:07 pm
    Yes,
    you have to uncheck something in the RAID Admin setup, but I’m away from the office and I can’t remember what it is. I think it’s disable write caching or something like that.
    There is a support note on the Apple site about it.
  • Lee Berger
    August 9, 2006 at 5:18 pm
    Yes, it’s uncheck “Allow Host Cache Flushing” and uncheck “Use Steady Streaming Mode”
    here’s the link
    https://docs.info.apple.com/article.html?artnum=302780
  • Aaron D hose
    August 9, 2006 at 5:30 pm
    There’s “drive write cache” and “controller write cache.” I’ll disable both, just to be safe and try again. Should you find out which one of the two caches should stay checked, pls let me know. 😉
    thx
  • Aaron D hose
    August 9, 2006 at 5:52 pm
    thx a lot, especially for the link to apple’s site. 😉
