Activity › Forums › Apple Final Cut Pro Legacy › DV25 – DV50 workflow questions
  • Rich Rubasch
    December 3, 2006 at 1:24 am
    Jerry’s comments notwithstanding, I’m not sure if you have much to gain just for a first pass DVD. I’d say do a few color correction tests to see if you can get satisfactory results with the DV material you already have.
    I do believe that DV material, if brought in via SDI, is uploaded to DVCPro50, it will not only look better than when it is brought in via firewire to DV, but you will definately have a better experience with it if you are keying or color correcting. Jerry is correct that the processing happens in uncompressed color space, but that pixel that has been changed has to be written BACK to the codec of the sequence. If the 4:1:1 space doesn’t allow for a certain black level or level of red etc, it would benefit from being written to a 4:2:2 codec. It will have more “space” or range for the color, lumanance etc.
    Just not sure for a first pass it is necessary. It leaves you some room to tell the client that the final video will be even better!
    Rich Rubasch
    Tilt Media
  • Rafael Amador
    December 5, 2006 at 4:23 pm
    Jerry i do not agree with you. Your right when you sais that FC when renders do it in uncompress.
    Is right that if you start with a 411 or 420 you are using the color information from a pixel to tint three other pixels, but if you are color correcting you are getting a new croma value in each of these pixels. If you go back to to 411 or 420 you are throwing away the croma of three in every four pixels.
    Christian, when I make a DVD I edit and color correct in DV, but before to export to Compressor I chage the setting of my sequence to 10b uncompress. The diference with exporting from the DV time-line is huge. So I recommend you your opction “C”.
    Salud,
    rafael
  • Christian Glawe
    December 6, 2006 at 12:18 am
    Ah… thanks for the input, Rafael! I’ll try this and see how it looks…
    Christian Glawe editor/compositor christian.glawe@yahoo.com https://homepage.mac.com/christianglawe/iMovieTheater5.html Pain is temporary… film is forever.
Page 2 of 2
