DV to quasi-HD – Interlacing, Resolution, Conversion…
I’ve got a handful of related questions on the technical side of a project and I figured it might just be best to gather them up in one thread. Perhaps the thread will help others, the way I have found some threads with related questions helpful for me.
I will state at the outset:
Input –> 720×480 DV, interlaced, 30fps
Output –> Open. In short, the highest quality output possible. I guess I will say the output should be playable on HDTV, and potentially high resolution at festivals.This brings up a handful of workflow questions.
1. Any Output Specs I should be targeting here, with these goals?
2. For upscaling the DV video to HD (will end up presumably as 1920×1080 with black on the sides) do I want to de-interlace the footage at any point?
2A. If deinterlacing should happen, at what point in the process?
– During conversion to “HD”?
– After conversion but during editing before filters / effects?
– At the very end when all else is done and ready for output?
– Never?3. Best Sequence Settings for working with the upscaled footage?
– The instructions I have seen tend to suggest converting to “HD” at ProRes422 (ordinary ProRes). I would naturally let FCP set the sequence settings to match the footage, but with my intended deliverable (HDTV / Festival Projection) are any settings in particular ideal?4. Is there any reason in particular that I would want to consider “720 HD” rather than 1920×1080, other than the fact that less upscaling is involved?
5. Smoothcam / Stabilize filters before vs. after De-Interlacing? Is there a recommended workflow here, assuming I need to deinterlace?
Thanks for any advice, as always.
