  • Posted by Patrick Bronte on July 13, 2010 at 2:43 am
    I’m trying to put together a doco short. Unfortunately, the resolution of the required stock footage came at 720 x 480 DV. But the footage of the talking heads I’ve shot is at HDV1080i/50. What would be the best way to try and match them up without losing any quality? Is Compressor the best tool to try and convert the DV footage to HDV? Can it be done at all?
    Any advice would be much appreciated….
    Patrick Bronte replied 16 years, 1 month ago 3 Members · 4 Replies
  • Michael Sacci
    July 13, 2010 at 3:42 am
    There is no way to upconvert DV to HD without losing quality. It will get softer than what you have. Do a hardware upconvert gives a better results. Using Frame Control in Compressor helps or using a plugin like InstantHD. But there is no free lunch here. DV footage will never match HD footage, unless the HD is shoot very poorly, then you may have a chance.
  • Zane Barker
    July 14, 2010 at 1:55 am
    First off DO NOT edit in a HDV time line. Use pro res! Better yet capture your HDV material as pro res.
    Then follow Michael’s advice.
    **Hindsight is always 1080p**
  • Patrick Bronte
    July 14, 2010 at 3:30 am
    Thanks heaps for that guys!
  • Patrick Bronte
    August 16, 2010 at 2:56 am
    THANKS FOR THAT ADVICE ZANE!
    If I’m capturing the HDV material as pro res, does it increase the quality or maintain the integrity of the footage a lot better than if captured in HDV? and/or does it make editing in a pro res timeline easier, producing a better final output?
    Is there any way to convert material captured in HDV to Pro Res?
    Your help here would be really appreciated!
    Regards,
    Pat
