Activity › Forums › Apple Final Cut Pro Legacy › DV Tape to FCP
  • Posted by Richard Walton on January 10, 2012 at 2:32 am
    I have some SD MiniDV archival tapes that I want capture video from and ultimately process in FCPX for online use. I have begun the process and am capturing and doing a rough cut edits in FCP 6 (Leopard). I have noticed some of the captured clips (NTSC 720×480) have a narrow vertical black margin on the left and right. Using the Motion Tab and increasing size to 102% is enough to eliminate these margins.
    -Motion Tab at 102%, Crop, or another method?? – which method will degrade the video the least?
    I plan to bring clips into Tiger and use “Encode Selected Video Files”
    480p, Higher Quality (xxx.mov encodes to xxx.m4v) to preprocess clips for final edits, audio & color balancing in FCPX
    -Is there an alternate means of processing the clips that will result in better quality clips?
    Dick Walton
    Natural History Services
    https://www.rkwalton.com
    Richard Walton replied 14 years, 8 months ago 3 Members · 4 Replies
  • Steve Eisen
    January 10, 2012 at 3:41 am
    Capture and edit in DV-NTSC. You not going to get any better quality by doing anything else.
    Steve Eisen
    Eisen Video Productions
    Vice President
    Chicago Final Cut Pro Users Group
  • Richard Walton
    January 10, 2012 at 5:14 am
    Thanks Steve –
    Any thoughts on my first question – how to remove black edges?
    Dick Walton
  • Chris Tompkins
    January 10, 2012 at 11:06 am
    If you’re going out to DVD or Tape, you will not see those edges on the final.
    But you got it right, you can zoom in a little to hide it. Like if you’re playing it back on a comp…
    Chris Tompkins
    Video Atlanta LLC
  • Richard Walton
    January 10, 2012 at 12:49 pm
    Steve:
    Many thanks for your ideas.
    Dick
    Dick Walton
