Activity Forums Apple Final Cut Pro Legacy DV stretched on export
  • DV stretched on export
    Posted by Mark Barroso on September 10, 2013 at 1:51 pm
    I’m sure someone answered this question 10 years ago but I can’t find the answer. Please help! I’m on deadline.
    These videos will be seen only on the web, using vimeo.
    I’m editing DV footage in FCP6 and the timeline is set to NTSC DV. All of the clips are sized 720 x 640. When I export the sequence using QT conversion, it says the current size is 637 x 477.
    When I look at the final QT file, it looks stretched, and indeed, the dimensions are 853 x 480. The odd thing is, when I bring back into FCP it’s 720 x 480 again.
    I’m guessing it’s the square vs. rectangular pixel issue, but I am loathed to re-export from the timeline again as I have 25 hours of video and each one takes about 2 hours. I can’t have it looking stretched on-line, and I’m uploading a test as a type.
    If I need to fix it, is there another, faster way to re-size the video before upload?
    Thanking you in advane
    Rafael Amador replied 13 years ago 2 Members · 2 Replies
  • Mark Barroso
    September 10, 2013 at 2:29 pm
    I just looked at the test on vimeo and yes, it looks stretched. So now I’m hoping someone here as a quicker fix than re-exporting from FCP. I have Handbrake, but that doesn’t look like you can adjust the size.
  • Rafael Amador
    September 11, 2013 at 2:49 pm
    If you are playing the clip with QT Player, is normal that looks distorted.
    QT interpretes everything as Squared Pixels (unless the footage is flagged with a different pixel aspect.
    Your DV stuff will look distorted in QT and also in any web site.
    You need to export keeping the 4×3 relation between wide and high.
    BTW, avoid “QT Conversion” unless you are making a web video.
    rafael
