Activity › Forums › Apple Final Cut Pro Legacy › DV sequence to ProRes sequence
Posted by Harry Kafka on January 21, 2009 at 5:05 pmI’m finishing a doc with extensive color correction.
It was shot in DV and my question is whether there is any quality difference in cutting and pasting the DV sequence into a ProRes sequence in order to get a better color correct as compared to using Media Manager to transcode the clips to ProRes first and then build a ProRes timeline.
Thanks for any advice.Rafael Amador replied 17 years, 8 months ago 3 Members · 5 Replies -
Russell Lasson
January 21, 2009 at 6:33 pmI would just duplicate the sequence, then change the compressor in sequence settings to ProRes HQ. You won’t gain any quality by transcoding the DV media to ProRes first.
-Russ
Russell Lasson
Ridgeline Digital Cinema Mastering
Universal Post
Salt Lake City, UT -
Rafael Amador
January 22, 2009 at 8:52 amHi harry,
Don’t go that way. The only thing you get transcoding in FC from DV to ProRess is much bigger files without any benefit. You are writing 8b information with 10b.
I suggest you a different way that have been giving me excellent results while working in DV:
Edit and CC in a DV sequence. When you are finished:
– Drop the Nattress Chroma Smooth/Sharpen. You must put it before any other filter.
– Change you sequence codec to ProRess.
– Set “Render all YUV material in High Precision YUV”.
– Export.
As I said, going from 8b to 10b without any Chroma filtering is just a waist of time and resources.
If you want to go properly from DV to Proress, or this way, or though a good capture card.
cheers,
rafael -
Harry Kafka
January 22, 2009 at 5:07 pmThanks Rafael,
One question about the Natress filter.
How do you adjust parameters?
Are the adjustments visible to the naked eye? -
Rafael Amador
January 23, 2009 at 6:02 pmHi Harry,
So far I’ve been working with the default setting. I think works perfect.
Of course select the correct one (interlaced/progressive) according to the footage, and in MODE, check the appropriate option according to the footage too:
– 411 for DV NTSC
– 420 for DV PAL, HDV or XDCAM.
Set it always as the first filter in the stack. I set it right before rendering (pain taking) because it cause always red-line when dropped on the clip.
Cheers,
rafael
