Activity Forums Apple Final Cut Pro Legacy DV recapture to uncompressed
  • DV recapture to uncompressed
    Posted by Gerret Warner on April 22, 2005 at 10:46 am
    On a tip, I recaptured my DV project in FCP HD to uncompressed 8-bit in order to have more control over color correction and to have crisper titles. But when I did–using Media Manager to create a new project– I was surprised to find that my sequence needed rendering, even though both recaptured footage and sequence were set to unncompressed 8-bit. Thinking that it might be titles I’d created in the DV sequence, I removed them, but no luck. Strangely, I’ve found that, if I match frame and then re-edit some of the clips, they show up as NOT needing rendering. Others still do. Anyone have similar experiences… or advice?
    GW
    Jerry Hofmann replied 21 years, 4 months ago 2 Members · 1 Reply
  • Jerry Hofmann
    April 22, 2005 at 3:26 pm
    What capture card? IO? or?
    Post the exact capture presets and sequence settings you are using for the uncompressed version…
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
