Activity › Forums › Apple Final Cut Pro Legacy › DV Quicktime export soft in middle !
  • DV Quicktime export soft in middle !
    Posted by Bob Cole on December 21, 2007 at 2:01 pm
    I just finished the online (8-bit uncompressed) for a very beautifully shot PBS documentary, and exported it two ways: 8-bit uncompressed, and NTSC DV.
    On the DV file, in the middle of the frame, during the credit scroll, we noticed softness. A line of type looks fine top and bottom, but the font softens and double-images a bit, when it hits the middle. This is a VERY subtle effect, and I don’t notice it anywhere else. The scroll was done in After Effects, and looks fine in the original and the 8-bit uncompressed export.
    I’m monitoring this via Kona LHe to a Sony 19″ component monitor, in component setting. When I tried to export a still frame to check this, the typeface looked bad everywhere due, I suppose, to field rendering.
    Why would a DV Quicktime have different quality in different parts of the frame? Or is it somewhere else in the chain?
    Bob C
    MacPro 2 x 3GHz dualcore; 10 GB 667MHz
    Kona LHe
    Sony HDV Z1
    Sony HDV M25U
    HD-Connect MI
    Betacam UVW1800
    DVCPro AJ-D650
    Bob Cole replied 18 years, 9 months ago 2 Members · 2 Replies
  • Ty Ford
    December 22, 2007 at 1:36 am
    soft CRT?
    Can you try it on different monitors?
    Regards,
    Ty
    Want better production audio?: https://home.comcast.net/~tyreeford/AudioBootcamp.html
    Watch Ty play guitar: https://www.youtube.com/watch?v=4RZJ9MptZmU
  • Bob Cole
    December 22, 2007 at 1:39 am
    Good idea (if I had one), but I really don’t think it’s the monitor; the same scene on the same monitor is pin-sharp when rendered 8-bit uncompressed.
    Bob
    Kona LHe
    Sony HDV Z1
    Sony HDV M25U
    HD-Connect MI
    Betacam UVW1800
    DVCPro AJ-D650
