Activity › Forums › Adobe After Effects › DV production and focus
  • DV production and focus
    Posted by Roberto on September 21, 2005 at 9:08 am
    hello
    here my work:
    I filmed a karate guy infront of White paper background . i used 4 ARRi
    filmlights, camera ( 3ccd Sony tvr dcr 900) , distance form camera to Person = 4m.
    I edit the video material with premiere and After Effects, my editing system is Canopus Easy DV. the out put is DVD.
    Problem:
    I have no Sharpness. The guy wears a White karate suite.so the only thing witch is in Contrast to the background is the face of the guy …but this is shimmerng , flickering and aou of focus.
    Question:
    What is the professional work progress with dv material:
    Are there any tips to make the Dv materail look better . like sharpener Plug ins for Premiere or AFX. i used the unsharp mask…but the result is not nice….. and also i am searching for a deflicker tool wich makes the video looks stable so that there is no noise………tricky …but there should be an solution
    thanx
    robin
    Chris Smith replied 21 years ago 2 Members · 1 Reply
  • Chris Smith
    September 21, 2005 at 2:30 pm
    Is it flickering on your Computer screen or just on output? If it’s just on output and you are using composite video to look at your image, high contrast areas will flicker. If this is the case at least use S-Video to monitor your output.
    Chris Smith
    https://www.sugarfilmproduction.com
