Activity Forums Apple Final Cut Pro Legacy DV Pal Workflow (qaulity)
  • DV Pal Workflow (qaulity)
    Posted by Gary Ellison on May 11, 2010 at 10:34 am
    Hey all,
    I’m running into a minor issue that I was hoping someone could clear up for me.
    Our footage is shot on dvcam as dv-pal, interlaced at 50fps. I capture into FCP using a Sony hdv/dvcam deck.
    I’ve always assumed that the workflow for this is if it goes in dv-pal, it comes out dv-pal. However, once I’ve finished with a project and do an export from it’s native timeline the quality is pretty shocking to me.
    However, when I go to export – options and pick pro res 422 dv pal anamorphic as the export codec it looks great. However! When I do this the interlace lines show up! I can play with removing these in Episode and get decent results, but I feel like it’s very long winded!
    Basically what I’m asking is what workflow can I use with dvpal anamorphic to achieve these results from the bat?
    Is there a way to capture dv tape as pro res? I just want the best possible quality from my footage.
    Any help would be much appreciated.
    Cheers.
    Stuart Simpson replied 16 years, 4 months ago 2 Members · 1 Reply
  • Stuart Simpson
    May 11, 2010 at 11:02 am
    Check your Quicktime preferences, and make sure “use high-quality video setting when available” is checked. This will show your DV footage at it’s proper quality.
    -Stuart
    7 MacPros – Kona 3, Kona LH & Kona LHi
    1 G5 – Kona LH
    xbox360, Wii, PSP, PS3
    https://www.speak.co.uk
