Activity Forums Apple Final Cut Pro Legacy dv pal to web sequence settings
  • dv pal to web sequence settings
    Posted by Paul Joseph on June 2, 2012 at 5:43 pm
    Hi there
    I’ve got some dv pal anamorphic footage that I need to cut together for a website. It’s going to be mixed with some stills, text and graphics created in after effects. I find that dv pal makes text and graphics look horrible. What sequence settings would you suggest for the best looking output?
    PJ
    Michael Gissing replied 14 years, 3 months ago 2 Members · 1 Reply
  • Michael Gissing
    June 2, 2012 at 11:32 pm
    ProRes422. DV is lower field so FCP should automatically apply the shift fields filter. As the content is for the web, you might want to consider deinterlacing this footage and using a progressive sequence.
