Activity Forums Apple Final Cut Pro Legacy dv pal quicktime
  • dv pal quicktime
    Posted by Nick James on January 23, 2011 at 7:50 pm
    hi, i have a dv pal sequence anamorphic 16×9 720×576 whenever i create a quicktime at current settings (through export- quicktime movie) the resulting film has some jagged edges around faces and some wide shots etc when palyed on other computers. anyone know if im doing anything wrong? the resulting qtime says dv 720 x 576 normal size 1049 x 576. (the only difference between the two computers is no blackmagic card on the others -surely this shouldnt matter tho as its a stand alone quicktime).
    the film is eventually for uk broadcast and im trying to provide an sd dv master.
    Nick James replied 15 years, 7 months ago 2 Members · 2 Replies
  • Jeff Greenberg
    January 24, 2011 at 12:10 am
    Don’t view it on a computer – view it via a monitor and it’ll look fine. You’re seeing interlacing artifacts.
    Best,
    Jeff G
    Apple Master Trainer
    Avid Cert. Instructor DS/MC
    Avid & Color Videos Vasst.com
    Compressor Essentials Lynda.com
  • Nick James
    January 24, 2011 at 1:31 am
    top banana. was really hoping that was the answer. great to hear…phew. N
