Activity Forums Apple Final Cut Pro Legacy DV-PAL conversion in FCP
  • DV-PAL conversion in FCP
    Posted by Nosweatjonny on August 30, 2006 at 11:57 pm
    I have footage shot in DV NTSC edited in FCP which needs to be sent overseas in PAL format(on a DVD). I exported from FCP as QT movie using DV PAL 48khz setting including DVD studio Pro markers. In compressor I also set it to PAL, and when I opened a new project in DVD Studio Pro, I also set it to PAL before importing the compressed footage. The chapters markers were in the wrong places, but It burned fine.We played it on a DVDplayer which outputs as PAL, connected to a PAL monitor, but the footage looks slightly jumpy and you notice way too many scan lines on moving objects. Am I doing something wrong here? anyone help? please? I know i didnt over-compress it cuz i use compressor almost daily and never had the problem with NTSC.
    Rene Hazekamp replied 20 years ago 2 Members · 1 Reply
  • Rene Hazekamp
    August 31, 2006 at 4:05 pm
    hi
    you should use compressor(2) to this. Though don’t use standard presets. I don’t have it on my computer here. but i’thought that it was best to choose all the better options and optical flow (in the second tab).
    hope this helps a bit
    Rene Hazekamp
    https://www.renehazekamp.com
