Activity › Forums › Apple Final Cut Pro Legacy › DV online to SDI 10bit Uncompressed
  • DV online to SDI 10bit Uncompressed
    Posted by Hawkfinn on October 30, 2007 at 9:38 pm
    I am ready to output my dv project to digibeta. All the footage was captured as dv. I am trying to prepare the timeline as much as possible on my system before bring the project to an online room w/ a digi deck. I know that on my FCP timeline, I should change the compressor setting to 10bit uncompressed. But how about the frame size? Should it stay at 720×480 (3:2), or be changed to 720×486 (CCIR60 40:27). I see that if I change it to 720×486, which is native SDI, the image becomes a little blurry. At 720×480, the image is native. Would the digibeta take 720×480? Would the Kona3 or BlackMagic card be able to hand 720×480 size without having to render the timeline? How do you do it???
    Thanks.
    Russell Lasson replied 18 years, 11 months ago 3 Members · 3 Replies
  • Russell Lasson
    October 30, 2007 at 10:09 pm
    I’ve been using 720×480 uncompressed with SDI for a couple of years. Maybe it’s wrong, but to me it’s better than the alternative of adding six lines and messing up the native file.
    Just as a note, if your original files weren’t DV but you digitized them to DV for editing, it would be better to redigitize them as uncompressed instead of just converting the files you digitized.
    -Russ
  • Rafael Amador
    October 31, 2007 at 3:45 am
    [Russell Lasson] “it would be better to redigitize them as uncompressed instead of just converting the files you digitized.
    Hi Russell,
    Sorry but I do not agree with what you say. There is not any reason for thinking that you will get something better when upgrading a DV to 10b Unc on capturing than making the upgrading in your time-line. IMHO the only thing you get are much bigger files.
    rafael
  • Russell Lasson
    October 31, 2007 at 5:02 pm
    [rafalaos] “There is not any reason for thinking that you will get something better when upgrading a DV to 10b Unc on capturing than making the upgrading in your time-line.”
    If the original source footage was DV (4:1:1 color space) then I completely agree. But if the footage was Beta SP or some sort of downconverted HD or something, then I’d suggest re-digitizing to stay away from a 4:1:1 hit.
    -Russ
