Activity › Forums › Compression Techniques › DV NTSC 4:3 passthrough in Compressor?
  • DV NTSC 4:3 passthrough in Compressor?
    Posted by Alan Langdon on February 16, 2011 at 4:59 pm
    I have footage captured in Final Cut which was captured in segmented files, due to a Fat-32 formated drive. So the files are 2GB + 0.2 GB = 10 minutes of DV NTSC footage, using Apple’s Final Cut DV NTSC codec. 2 files make up 10 minutes of footage with timecode (came from miniDV tape).
    I want to re-export (not recapture, the footage is over 30 hours!) these clips, so that the two combined files become a single 2.2 GB DV NTSC file.
    Is there a passthrough option in Compressor? So the footage retains the timecode and doesn’t loose any native image/sound qualities? If I chose DV NTSC 48khz codec, will this pasthrough be achieved or will it re-encode no matter waht?
    Any help much thanks!
    Alan Langdon replied 15 years, 7 months ago 1 Member · 0 Replies
  • 0 Replies
