Activity Forums Compression Techniques DV NTSC 4:1:1 to 4:2:0 color sampling
  • DV NTSC 4:1:1 to 4:2:0 color sampling
    Posted by Travis Dao on April 28, 2005 at 8:54 pm
    Hi all,
    I encode a lot of DV NTSC video for the web. I’ve been told that the best way to improve DV NTSC color sampling (4:1:1) for the web (4:2:0) is to render it using a (4:2:2) codec like MotionJPEG and DV50. I use Premiere Pro 1.5 and Final Cut Pro to capture, is there a way to change the color sampling of DV NTSC upon capturing? Or is there a compression software that will adjust the color sampling before encoding?
    Travis
    Ben Waggoner replied 21 years, 4 months ago 3 Members · 2 Replies
