DV Mini audio compatibility problems
Hi
We working with mini-dv documentary footage that was digitized either using 48KHz or 32KHz so that the mov files can not be edited on the same timeline without rendering. Too much material to re-digitize. If we convert material to prores that bloats the data and we are already daisy chaining drives. Any suggestions? Also we are getting different Audio Rates. For example: 32kHz vs. 31.999KHz. Why does this happen?
Many Thanks!
