Activity Forums Adobe Premiere Pro dv material to premiere
  • dv material to premiere
    Posted by Mike Strasser on August 18, 2005 at 11:26 am
    Hi there,
    my customer imported his video material from a dv cam by fire wire to hard disk. When I import these avi files (between 4 and 9 GB size) premiere pro 1.5 only imports about 2 or 3 minutes.
    On another workstation with premiere pro 1.5 it
    John Baum replied 21 years, 1 month ago 4 Members · 9 Replies
  • 9 Replies
  • Mike Velte
    August 18, 2005 at 11:53 am
    You will need to capture the files using Premiere. The capturing app wraps the DV file with a header designating the codec. Your PC does not have the correct codec.
  • Mike Strasser
    August 18, 2005 at 7:58 pm
    Hi mike.
    I can import the movie files completly in after effects.
    Therefore my system has the codec.
    But I don
  • Steven L. gotz
    August 18, 2005 at 8:30 pm
    Your customer captured the material to the wrong type of AVI and it is Premiere Pro’s fault? Interesting way to look at it.
    Steven
    Adobe Premiere Pro 1.5.1 / After Effects 6.5 Pro https://www.stevengotz.com
    Learning Adobe Premiere Pro 1.5 https://www.lynda.com
    Contributing Writer, PeachPit Press, Visual QuickPro Guide, Premiere Pro 1.5
  • Mike Strasser
    August 18, 2005 at 9:42 pm
    But why can After Effects and media player handle the files and premiere not?
  • Steven L. gotz
    August 19, 2005 at 2:18 am
    Just guessing, but they are probably type 1 instead of type 2.
    AE can handle it, but Premiere Pro does not have the same exact engine or access to codecs.
    Steven
  • Steven L. gotz
    August 19, 2005 at 2:28 am
    By the way, there is a free utility to make the conversion from Type 1 to Type 2 on the Ulead web site.
    https://www.ulead.com/download/dvconverter/download.htm
    Steven
  • Mike Strasser
    August 19, 2005 at 3:21 pm
    Yeah. This works.
    I converted the files with the ulead tool.
    There
  • John Baum
    August 19, 2005 at 5:03 pm
    That program has a problem with files over 4GBs. It causes just the audio problems you describe.
  • John Baum
    August 19, 2005 at 5:25 pm
    Maybe this program will work better for you.
    https://www.videohelp.com/tools?tool=DVdate
