Activity Forums Avid Media Composer DV Import Settings…
  • DV Import Settings…
    Posted by Jimmy Stewart on January 19, 2007 at 2:37 pm
    Hello,
    I shot a project with a Canon XL-1. I have high rez quicktimes of the footage and I want to import into Avid Xpress Pro. What are my proper import settings for a dv project:
    Aspect Ratio:
    Color Levels:
    File Field Order:
    Alpha:
    Jimmy
    Jimmy Stewart replied 19 years, 8 months ago 2 Members · 3 Replies
  • Toptop1200
    January 19, 2007 at 3:30 pm
    Okay. I think these are the correct settings:
    Aspect Ratio: 601/709, non-square
    Color Levels: 601/709
    File Field Order: Lower Field first
    Alpha: Ignore
    Hope that helps.
  • Toptop1200
    January 19, 2007 at 3:37 pm
    The above said, it is probably also worth checking with whoever provided you with the QuickTime files how they were exported as far as ‘File Field Order’ and ‘Color Levels’ settings go. There are a number of different options for QuickTime exports.
  • Jimmy Stewart
    January 19, 2007 at 3:53 pm
    That helps. Thanks!
