Activity Forums Avid Media Composer DV import into Avid
  • DV import into Avid
    Posted by John Hill on August 13, 2011 at 5:43 am
    I’m trying to import from a miniDV tape into Avid 5.5. When I make the audio project format 32khz, I can import fine except that the audio is warbly. I assume that this is because the bit setting in the audio project is 16bit (no choice for 12bit, which is what my dv tape is).
    Is there anyway I can import the tape without bad audio? I tried importing at 44khz and 48 but the import would only last 15 seconds (although the sound was not warbly).
    THANK YOU.
    Power MAC Dual core Intel, 6GB memory, 2.66ghz
    John Hill replied 15 years ago 1 Member · 0 Replies
  • 0 Replies
