Activity Forums Apple Final Cut Pro Legacy DV footage needs rendering. WHY?
  • DV footage needs rendering. WHY?
    Posted by Ed Stevens on September 3, 2005 at 6:54 pm
    My SYSTEM
    MAC dual G5 2.5 gig. 4.5 gb RAM. OS 10.3.8
    Blackmagic Decklink Extreme card v4.8b
    FCP 4.5 production Suite
    500GB G-Raid Firewire800
    Decks = Beta-SP, DVCpro, DigiBeta.
    Audio Mix = Mackie 1604 VLZpro
    I believe I have the stock display card
    I am working on a project and have been sourcing from Digibeta
    through component. I needed 2 clips from DVCpro and digitized that through firewire. The DVCpro footage needs to be rendered on the timeline. Why?
    Thanks in Advance.
    ED
    Alexander Serpico replied 21 years ago 3 Members · 2 Replies
  • David Roth weiss
    September 3, 2005 at 7:46 pm
    Ed,
    Why not? Two different media types with different pixel dimesions on the same timeline = something has to happen. Either you render the DV material on the timeline, or transcode to the same format as the material on your timeline, probably BM 8-bit, 10-bit, or JPEG.
    DRW
    (BTW, I have the same setup as you except on a G5 2.3)
  • Alexander Serpico
    September 3, 2005 at 10:04 pm
    compare the compressor and frame sizes of you captured media to your sequence. you will find your answer.
