Activity Forums Apple Final Cut Pro Legacy DV footage has a juddder even after render
  • DV footage has a juddder even after render
    Posted by Ciller on September 20, 2006 at 10:14 am
    I am using Digibeta footage in an uncompressed 10 bit seq and a small amount of DV footage
    however after i render the footage and watch it back the digi is good but the DV has a bad judder.
    it s like the field domminance is set wrong but ive tried upper lower and not set but to n avail.
    This problem however appears to stop when i view the sequence through my computer monitor instead of through my sony monitor through the AJA Kona card?
    Jack Fox replied 19 years, 11 months ago 4 Members · 3 Replies
  • Rafael Amador
    September 20, 2006 at 4:17 pm
    I have a BM and work in PAL. When I work in a 10b (Up-first in PAL) sequence and I bring DV (Low-first) the video cards correct the fields order. But the problem is that FC try to do the same (by applying a Shift-fields filter) and the final result is that the field order is wrong again. You must uncheck the filter applied to you clips and when rendering its looks OK.
    May be happens the same with the AJA.
    salud,
    Rafael
  • Kevin Monahan
    September 20, 2006 at 5:07 pm
    You will have to reposition the DV clip vertically by 1 pixel in any 601 sequence to avoid field reversal.
    Kevin Monahan
    Take My FCP Master’s Workshop!
    fcpworld.com
    Pres. SF Cutters
  • Jack Fox
    September 20, 2006 at 6:11 pm
    By chance, is the color red involved?
    jmf
