Activity › Forums › Apple Final Cut Pro Legacy › DV footage and USB 2.0
Posted by Scott Dodds on October 27, 2009 at 9:25 pmHi. Sorry, I know this is rudimentary but I get inconsistent answers.
In using mini-DV, basic 3.8 megs/sec throughput, can I use an external USB 2.0 disk to capture to and edit from with my source materials on it? I have always used FireWire but now have a laptop without it. Will it work, given the inconsistent (although faster) datarate?
Thaxter Clavemarlton replied 16 years, 11 months ago 4 Members · 5 Replies -
Zane Barker
October 28, 2009 at 4:42 am[scott dodds] “can I use an external USB 2.0”
NO USB is not good for video. USB works with bursts of data therefore it just cant handle the constant data rate that video requires.
[scott dodds] “Will it work, given the inconsistent (although faster) datarate? “
A faster burst is still a bust.
Think of USB like a drinking fountain where somebody keeps pressing down and letting go of the button. Its still hard to fill a glass of water. all that USB 2 gives you over USB 1 is a bigger hole on the fountain it still does not stop the burst of water.
There are no “technical solutions” to your “artistic problems”.
Don’t let technology get in the way of your creativity! -
Steve West
October 29, 2009 at 12:18 amI’m sure Zane is correct- but I do it all the time. The biggest problem I have is with “green” drives that spin down when they’re not in use.
Scott Dodds
October 29, 2009 at 1:20 amYes, this was my understanding too. I just have had so many people tell me otherwise that I was beginning to doubt it.
Thanks.
Scott Dodds
October 29, 2009 at 1:25 amYes, I hear this too! My problem is my firewire port died on my laptop and I want to use it in the field.
I think what confused me is that some newer consumer camcorders use USB instead of FW now to transfer from the camera to the computer. But now that I think it through, that’s just data being copied and so a constant data rate in that context isn’t important. thanks again
October 30, 2009 at 4:36 am[scott dodds] ” that’s just data being copied and so a constant data rate in that context isn’t important. “
Until the transfer rate lags the medium, like a transfer to or from a rolling tape.
