Activity Forums Adobe Premiere Pro .dv file on a PC
  • .dv file on a PC
    Posted by Eyal Gordin on July 6, 2005 at 8:43 am
    I was given dv files from the post house. They have a Mac and gave me .dv clips. PPRO tells me it is not a supported format. How do I use it without convirting and losing quality?
    Eyal Gordin
    Designer of the unique
    http://www.framedmemory.com
    Eyal Gordin replied 21 years ago 3 Members · 3 Replies
  • Mike Velte
    July 6, 2005 at 11:31 am
    Pro should support the files, but you will need Quicktime player installed first.
  • Dave Friend
    July 6, 2005 at 4:16 pm
    Hello Eyal,
    Try changing the file extension from .dv to .mov and see it that helps.
    Dave
  • Eyal Gordin
    July 11, 2005 at 6:16 pm
    Thanks Dave, that helped. It doesn’t change and quality, does it? Also, I was sent another file that is 3.2 Gig. on my computer it won’t open and it is reported as 1.99 gig. Is there a 2 gig limit on Windows that you know of? Can I change that?
    Eyal Gordin
