Activity Forums Adobe Premiere Pro dv device play button grey-out
  • dv device play button grey-out
    Posted by Reko Tomo on January 22, 2008 at 7:18 am
    I’ve been using CS3 for almost a year.
    Never had trouble before in capturing,
    until today :
    I can’t press all the buttons but REC button
    when I want to capture my handycam
    from dv device in CS3 – which has status ONLINE.
    (they are greyed-out, except the REC button).
    lucky enough, I still can capture
    by press PLAY on my handycam, then
    press REC on the CS3 capture interface.
    Though it’s not a big problem then
    (since I still can do the capture)
    but it really annoyed me.
    I’ve tried using small DVcapture program
    (DV-CaptureFlux) and all the button work properly.
    So I assume there’s something wrong within CS3.
    Will re-install CS3 fix the problem ?
    I’ve read from internet that in CS3
    we can’t just do re-install PP-cs3.
    We need to do clean install, that’s it
    remove ALL Adobe CS3 application,
    then redo a fresh clean install.
    Is it true ? because it will be
    a bit aggravating to have un-install all CS3
    then install back all while the problem is only PP-cs3.
    Oh my… PP-CS3 is a nice program,
    but since it’s all integrated to other CS3 program
    I think it’s difficult to fix when
    there’s a problem with one of the program.
    Any kind of answer will be greatly appreciated.
    Thank you in advanced.
    Reko Tomo replied 18 years, 7 months ago 1 Member · 0 Replies
  • 0 Replies
