Activity Forums Panasonic Cameras DV Deck/Transferring question…
  • DV Deck/Transferring question…
    Posted by Jameslhart on January 15, 2007 at 3:01 pm
    Hi there,
    Not to long ago, my Panasonic AG-DVX100 stopped transferring video via the firewire port. After asking on here I was told that the VTR (sp?) was fried, and that I should either get a DV Deck or a little mini DV Camcorder for video transfer.
    I went with the cheaper option and bought a Sharp Viewcam, lovely little camera. But the problem is, when I insert a DV Tape that’s been recorded on using my AG-DVX100, the picture is a mess, and you can’t make out anything at all.
    Please note:
    I’m from the UK.
    The AG-DVX100 is from the U.S.
    And the Sharp Viewcam is from the UK.
    I’m guessing the problem is the where the AG-DVX100 is from. I’m guessing if the AG-DVX100 was from the UK I wouldnt have this problem.
    So now, if the above is right (correct me if I’m wrong), does anybody know of a U.S. Mini DV camcorder, that would be compatible with the footage I’ve taken?
    Kind Regards
    James
    Barry Green replied 19 years, 7 months ago 2 Members · 3 Replies
  • Barry Green
    January 15, 2007 at 8:10 pm
    Any NTSC miniDV camcorder will play back NTSC DVX footage. Sounds like you’re trying to play an NTSC tape in a PAL camera, and that’s not likely gonna work.
    Get the most from your DVX camera. The DVX Book and DVX DVD are now available on ebay and at Amazon (https://www.fiftv.com/db)
  • Jameslhart
    January 15, 2007 at 9:28 pm
    Well its a PAL tape, but recorded on a NTSC AG-DVX100 camera.
  • Barry Green
    January 16, 2007 at 4:20 am
    No such thing. Tapes aren’t PAL or NTSC, they’re just data tapes. If you recorded it on a US/NTSC DVX, then the footage on the tape was recorded in the NTSC format, and won’t play in a PAL-format camera.
