Activity Forums Apple Final Cut Pro Legacy DV Deck recommendation with Final Cut?
  • DV Deck recommendation with Final Cut?
    Posted by Murray White on June 3, 2005 at 6:52 am
    Hope this isn’t too off-topic, but I need to get a DV deck to use with Final Cut Pro.
    Any recommendations? Or is there a better place to ask this question?
    Gunner Jones replied 21 years, 3 months ago 6 Members · 6 Replies
  • Jerry Hofmann
    June 3, 2005 at 3:03 pm
    Any Sony or Panasonic machine is great. Stay away from all others… DSR-11’s are certainly workhorses.
    Might consider Sony’s new HDV machine, it also plays DV, DVCAM…
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
  • Gunner Jones
    June 3, 2005 at 5:20 pm
    Sony DSR-45
    Sony DSR-2000
    Hopefully you’ve got the dough to get yourself a decent deck. Anything under $2500 is suspect in my book. A DSR-20 is about the lowest I’d go. I really don’t like the DSR-11. It’s kinda cheap, has no TC and shuttles slower ‘n molasses.
    O&O-Gunner Productions
    FCP-Avid-After Effects
  • Trevor Ward
    June 3, 2005 at 7:00 pm
    Could someone tell me WHY you’d use a deck versus using a cheap camcorder? I use my 6-year old sony miniDV to capture and export. If all I’m doing is miniDV, why would I spend $3000 for a deck?
  • Graeme Nattress
    June 3, 2005 at 7:46 pm
    The HDV deck is a bad choice for a deck, IMHO, due to it being a camcorder mechanism that doesn’t take big tapes and doesn’t write any external TC of any kind. You’re far better off buying the HDV camera to use as a deck, as then you get a camera too. I really think the Sony HDV deck is a bit of a con.
    However, as you point out the DSR-11 is great, as is the DSR-25, and both a dual standard NTSC / PAL which is really useful.
    Graeme
    http://www.nattress.com – Film Effects for FCP
  • Chris Poisson
    June 3, 2005 at 8:00 pm
    Trevor,
    There are a ton of people in here who do what you suggest. Some have several camcorders they get cheap on Ebay in case one fails. This a perfectly sensible workflow. That is, as long as the camera is controlable via Firewire.
  • Gunner Jones
    June 3, 2005 at 9:09 pm
    Let me count the ways:
    Shuttling Speed. Faster on and off the heads. Rack mountable. Easy to load and eject. Meant to be on for long hours (fans, etc.). Faster FW ports, component and SDI output options, TC presets, Edit to Tape with Sequence TC, Longer use/greater wear and tear, Higher res monitoring. TC displays. Full size cassette DVCAM capability. Switchable PAL/NTSC options.
    Most people give this as their chief reason: You can avoid wearing out the camcorder’s more fragile deck mechanism.
    But I think the above points are more salient, especially for editors worth their salt.
    Speed/Convenience/Features is what it’s all about.
    A LOT of reasons that a full-time hard core editor needs to get the job done expeditiously.
    If you’re a hobbyist, student, beginner or don’t do a whole lot of work all the time, a camcorder is fine to use until you step up to the big leagues.
