Activity › Forums › Apple Final Cut Pro Legacy › DV Compression issues
  • DV Compression issues
    Posted by Cdivak on November 8, 2007 at 3:37 pm
    Hey,
    I’m not sure what the best way to go about this, to preserve the best quality.
    I edit my projects shot on DVX100 24PAdvanced in FCP in the native Firewire DV Codec. When I’m
    finished with the project, I lay it down to a Digibeta at 720 X 486,
    using the AJA card but there’s some slight distortion going on. Very
    minimal. Is it better to export out my sequence at the DV codec as a self contained quicktime?
    Is there a loss of quality doing that? I know theoretically, there
    shouldn’t be a loss in quality, but I feel like something is getting
    slightly compressed again. Am unsure what the exact process is when
    creating that quicktime. Also is there a better way? Mini -dv via
    firewire, but isn’t that also compressing my project slightly? Thanks
    for the help.
    Chuck
    Paul Escandon replied 18 years, 10 months ago 2 Members · 1 Reply
  • Paul Escandon
    November 8, 2007 at 3:45 pm
    Hi Chuck,
    It’s my understanding that Final Cut Pro will not recompress images on output when you use File > Export > Quicktime movie UNLESS there is something within that specific clip that Final Cut needs to render. Obviously, when it renders due to an effect, a filter, or titles/graphics, it’s going to have to render and that would add a second generation of compression to the video. If, however, most of your video is straight cuts then no recompression happens unless you check the box “Recompress all frames” – but there’s no need for you to check that box.
    What I’m saying only applies if you’re using the File > Export > Quicktime movie (not Quicktime conversion) and if you’re exporting to the same format that you captured in and that your timeline is in – in this case DV25.
    Hope that helps.
    Paul Escandon
    Producer | Director | Editor
    Apple Certified Trainer – Final Cut Pro
    Oremus Productions
    http://www.oremusproductions.com
    Adjunct Professor of Media
    John Paul the Great Catholic University
