Activity Forums Adobe Premiere Pro DV Capture/export issue
  • DV Capture/export issue
    Posted by Sarcasmo123 on August 31, 2007 at 9:04 am
    Im running premiere pro on a resonably well spec’d pc but im having problems with captured DV. When im capturing, the video in the capture window has wavey lines through it.. in both the editing windows, its plays back fine and i can edit as normal, but when i export, the video once again has the wavey lines running through it.. I know theres many possible reasons for playback problems in premiere, but given the type of problem i describe, can anyone advise me as to where the problem most likely is? any help would be very much appreciated…..
    Shane
    Blast1 replied 19 years ago 2 Members · 1 Reply
  • Blast1
    August 31, 2007 at 8:36 pm
    First of all you need to supply a lot more information, like your system specs and what you are capturing the dv from and through what?
