Activity › Forums › Apple Final Cut Pro Legacy › DV capture
DV capture
Posted by Randy Johnson on June 18, 2007 at 2:36 pmAh yes sPlit:) yes thats what I want to do, its strange FCP doesnt do that well maybe in version 7.0. Thanks for the work around.
Randy
Randy Johnson replied 19 years, 3 months ago 2 Members · 4 Replies -
Tom Wolsky
June 18, 2007 at 2:46 pmMost likely not. As systems move away from tape this becomes less and less important.
All the best,
Tom
Author: “Final Cut Pro 5 Editing Essentials” and “Final Cut Express 2 Editing Workshop” Class on Demand “Complete Training for FCP5” and “Final Cut Express Made Easy” DVDs
Randy Johnson
June 26, 2007 at 2:43 amTom,
I have another question, I do weddings and I like to capture all my footage at once. In my old windows system I could start it capturing and walk away it would automaticly break up my clips(which we discussed) it would also make big clips if neccesary I just ried capturing a wedding in FCP and it kept stopping at 2 gigs, the only way I could get around this was to change the cut off amount but then I needed to guess on how much space it would use up. Is there a setting im missing?Randy
Tom Wolsky
June 26, 2007 at 3:32 amLot of questions here. You capture your material in long chunks and use DVD Start/Stop Detect to break it up.
https://www.fcpbook.com/Video5.html
There should be no breaks at the 2G size if the drive is properly formatted to Mac OS Extended.
All the best,
Tom
Randy Johnson
June 26, 2007 at 11:31 amI figured it out, I was capturing across a network to a NTFS drive that must have been it. I just will have to capture to a Mac drive then copy it to my server.
Thanks again
Randy
