Activity Forums Apple Final Cut Pro Legacy DV Cam signal?
  • Neobe Velis
    March 18, 2006 at 11:43 pm
    I’m trying to print to tape (minidv) but I need to do it in DVCAM. I’m not having much luck with the manual and i can’t seem to figure out how to do this. There is no sequence setting for DVCAM and I don’t see it in the options under “Print to Tape”. How do I get a sequence that was done in DV NTSC 48khz to a minidv tape in dvcam?
    I’m trying to submit this to access tv for someone and they require DVCAm. My deck is minidv only.
    Neobe
  • Shane Ross
    March 19, 2006 at 12:59 am
    NVelis…please start a new topic if you have a new question.
    If you deck is MiniDV only, it will not record DVCAM. That isn’t an option you set in FCP…it is a deck setting. The signal is the same, only DVCAM runs slightly faster than miniDV. 60 min on MiniDv is 40 min on DVCAM.
    If they insist on a DVCAM output, you will need to rent a DVCAM deck.
    Shane
    Alokut Productions
    http://www.lfhd.net
Page 2 of 2
