DV CAM – Final Cut Pro
Hi folks,
A few years ago, I shot some footage on PD-150 in DVCAM on mini-DV tapes. Now, I’m trying to feed this footage into Final Cut Pro, using a friend’s Panasonic 3.1. The tapes play fine in the camera, they play without any obvious problems in the capture viewer (mabye skipping a bit), but when I try to capture, the image plays in slow motion then freezes, and a message comes up saying ‘dropped frames during capture – aborted’.
I assumed that if the tapes played in the camera and the viewer they could capture. I’m using standard preset 48 NTSC. Is there another setting I should use or can I simply not capture using anything but A PD-150 or another DVCAM-friendly camera?
Any advice would be much appreciated.
