Activity › Forums › Apple Final Cut Pro Legacy › Dust remover in video
  • Dust remover in video
    Posted by Joe Baur on May 30, 2016 at 1:28 pm
    Hey everyone — I know there are posts on how to remove dust from video using a pixel blaster plugin in Final Cut Pro X, but I haven’t been able to find anything for older versions, like 7. Anyone have any ideas or suggestions?
    Nick Meyers replied 8 years, 5 months ago 4 Members · 6 Replies
  • Nick Meyers
    May 31, 2016 at 9:46 am
    you mean like a single dead pixel, or blob,
    or constant dust all over ike ah old film print?
    for a single 1frame blobs i’ve used Too Much Too Soon’s”Hair” (free, i think)
    others out there include:
    Eureka – Pixel Fixer
    1z1Tools – pixelRebirth
    CHV – Repair-collection
    nick
  • Joe Baur
    May 31, 2016 at 11:59 am
    Constant dust. CHV has a dirt remover plugin, I’m seeing, that might be worth a shot. I can get rid of these things easily on stills in Photoshop, but I’ve yet to learn how to do it in Final Cut Pro with video.
  • Nick Meyers
    May 31, 2016 at 12:46 pm
    Yes, i’ve used that CHV plug in, it does an OK job.
    there’s another I know from a restoration job i did a few years ago: Furnace-core from The Foundry.
    VERY expensive, and also discontinued, i now see.
    I think resolve might offer some automated dust-busting, but I’m not sure.
    i know it does a very slick job doing it manually: click a piece of dust, and it;s gone,
    but you don’t want to do that for the whole film!
    our externe cue on the restoration job was that we did a pass with furnace core,
    which cleaned up a lot,
    then had to zap a fair bit more manualy.
    that’s pretty much the norm.
    nick
  • Mark Suszko
    May 31, 2016 at 9:55 pm
    Digital Heaven has something that might work
  • Daniel Figueiredo
    April 4, 2018 at 7:10 pm
    Nick,
    I can’t figure out on how to use “Too Much Too Soon” hair removal on my video. Would you be able to explain that to me? I am not good with computers and having a very hard time with this. Your help will be much appreciate it.
    Thanks so much.
    Daniel
  • Nick Meyers
    April 5, 2018 at 5:41 am
    what sort of problems are you having?
    it’s pretty simple, so can only work in a simple way.
    it can help cover up a small, straight hair that is not moving,
    or a small spot.
    there are two position markers, P1 and P2, you use them to define the start and end of the hair.
    if it’s a spot, the start and end are basically in the same place.
    the filter then substitutes that area from the next or previous frame,
    and there’s a other control where you can create an off-set, so you wind up replacing the hair or spot with another part of the image.
    it’s limited for actual hairs, and pretty good for single frame spots.
    for a single frame spot, you have to blade the problem frame, then apply the filter.
    i hope that helps,
    nick
