Activity Forums Adobe After Effects “Dust” or something appearing in comp
  • “Dust” or something appearing in comp
    Posted by Martin Camenius on February 17, 2012 at 10:06 am
    Hey!
    I’m stuck, I don’t know what to do. I don’t know why, but “dust”/small particles or what you might call them appears in my comp.
    What I’ve done is that I’ve put a couple of copies of our business logo in a comp, and sort of put them under each other to create the illusion of 3D. With a camera and an adjustment layer I’ve made the logo “fly around” in the comp, but something is definitely messed up.
    At first I used .eps-files but when I thought that that might be the problem I converted them to .psd, but that doesn’t fix it. I’ve tried both CMYK and RGB.
    I assume it has something to do with all the layers, but I’ve done “this kind of thing” before and it’s never been like this before.
    I would REALLY appreciate any and all help regarding this.
    Martin Camenius replied 14 years, 7 months ago 3 Members · 4 Replies
  • Joseph W. bourke
    February 17, 2012 at 3:02 pm
    It sounds to me like maybe a bad alpha channel. Is it possible that the logo was originally on a solid, then cut out to make the alpha in Photoshop, using the magic wand tool? If so, what very often happens is that the tolerance on the background color pick misses a bunch of pixels, resulting in the “dusty” look you’re talking about. I hope that’s it – otherwise, I’ve got nothing. A quick check to see if it’s the alpha would be to put a mask around the logo as tight as you can get it, and see if the schmutz goes away.
    Joe Bourke
    Owner/Creative Director
    Bourke Media
    http://www.bourkemedia.com
  • Martin Camenius
    February 17, 2012 at 3:10 pm
    Thanks for your reply, but unfortunately that isn’t the case. It’s a clean alpha channel… :/
    I’ll work around it and come up with something else, but would be great to know what it is for future reference.
  • Mato Kokotic
    February 17, 2012 at 9:59 pm
    Do you have a light in precomp?
  • Martin Camenius
    February 20, 2012 at 7:56 am
    No, no added light sources.
