Activity › Forums › Adobe After Effects › duration of work area
  • duration of work area
    Posted by Anthony Dupsta on September 18, 2006 at 6:32 pm
    I want to find a quick way to find the duration of my work area. For instance, my 100 frame comp has a work area that starts on frame 11 and ends on 76, either I do the simple math of be lazy and have it done for me by going into the render que. Is there another way to do it beside having to create a movie?
    Roland R. kahlenberg replied 20 years ago 3 Members · 4 Replies
  • Julian Sixx
    September 18, 2006 at 6:52 pm
    Hi
    Composition=>Trim comp to Work Area and now hit the End key=>Undo.
    BTW,what is the shortcut for Trim Comp to work area,i can’t find it in the shortcuts.txt file?
  • Roland R. kahlenberg
    September 18, 2006 at 7:09 pm
    When you drag the work area’s in/out points, the Info Window will provide the info you want – unless I’ve been imagining all of it.
    HTH
    Roland Kahlenberg
    broadcastGEMs
    customizable animated backdrops with Adobe After Effects project files
  • Anthony Dupsta
    September 19, 2006 at 12:16 am
    Got it thanks for the tip. Am I a bad person for always having my info window hidin? I never use it. Now I need to find a place for it!
    Thanks again
    September 19, 2006 at 5:55 pm
    There are occasions when it gets in the way and that’s where the Tab key comes in handy. Hiding or showing it is a matter of using the Tab key. Lots of power there.
    Cheers
    Roland Kahlenberg
    broadcastGEMs
