Activity › Forums › Apple Final Cut Pro Legacy › duration of my clip time ??????/
  • duration of my clip time ??????/
    Posted by Andy Blanc on April 11, 2007 at 6:09 pm
    I right click my mouse…to see my duration…..to see if i’m at 5 seconds for instance….
    and it says 144
    where is my time in number of seconds…..for that clip?
    how can i fix this? never saw this before…..
    please help
    Andy Blanc replied 19 years, 5 months ago 2 Members · 6 Replies
  • Russell Lasson
    April 11, 2007 at 6:14 pm
    Right click on the timeline counter/ruler thing and change it from frames back to Non-Drop Frame or Drop Frame.
    -Russ
  • Andy Blanc
    April 11, 2007 at 6:18 pm
    Hi russell
    i am on the timeline…and i cant figure out….where to look…..
    exactly…..what is it under???
  • Russell Lasson
    April 11, 2007 at 6:31 pm
    Right click on the counter just to the right of the RT switch. A menu should come up that says
    Non-Drop Frame
    Feet+Frame
    Frames
    etc
    It sound like it is set to Frames. Change it to Non Drop Frame
    -Russ
  • Andy Blanc
    April 11, 2007 at 6:38 pm
    russell….i have one morre question…
    on my audio…..
    i see the grey bars……..with the pink line thru it…
    i like the pink line…..
    how do i get rid of the grey thick bars…
    thank you for your help
  • Russell Lasson
    April 11, 2007 at 6:49 pm
    [andy Blanc] “i see the grey bars……..with the pink line thru it…
    how do i get rid of the grey thick bars…”
    So pink line good. Grey bar bad.
    Pink line toggle on an off: the little mountain with the dots at the peak and valley on the lower right of the timeline.
    As for thick grey bars, do you mean the little grey bar usually above the pink line? or the audio waveform of a bars and tone signal?
    As for the little grey line, don’t have a clue how to get rid of it.
    If you’re seeing a huge grey bar behind the pink line, it’s probably an audio waveform. So go to the triangle that looks like a play button on the lower right of the time line, select it and turn off “Show audio waveforms.”
    Is that what you’re seeing?
    -Russ
  • Andy Blanc
    April 11, 2007 at 6:57 pm
    You are the best…..
    how did i not know that….
    thank you….
    again!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
