Activity Forums Adobe After Effects Expressions .duration not working
  • .duration not working
    Posted by Paul Roper on May 15, 2013 at 10:32 am
    Hello,
    I’m trying to obtain the duration of a layer, but AE refuses to co-operate. It just gives me the error “Class: ‘Layer’ has no property or method named ‘duration’. It bloody does have “duration”!
    I’ve created a text layer and put into the source text the expression:
    thing=thisComp.layer(“95253_00_02_MM30_Killed_Key_test.mov 2”);
    thing.duration
    I’ve also tried:
    thisComp.layer(“95253_00_02_MM30_Killed_Key_test.mov 2”).duration
    What is After Effects’ major malfunction?!
    If I modify the expression to:
    thing.source.duration
    …then it works…but gives me the duration of the source footage, ignoring the in/out points I’ve set on that layer. I’ve made a temporary workaround, subtracting the inpoint from the outpoint:
    thisComp.layer(“95253_00_02_MM30_Killed_Key_test.mov 2”).outPoint-thisComp.layer(“95253_00_02_MM30_Killed_Key_test.mov 2”).inPoint
    But why won’t “duration” just work?!
    – Paul
    Todd Kopriva replied 13 years, 4 months ago 3 Members · 3 Replies
  • Dan Ebberts
    May 15, 2013 at 4:33 pm
    As you’ve discovered, duration wasn’t implemented as a layer attribute in the expression language. I always use some combination of inPoint, outPoint, and startTime.
    Dan
  • Paul Roper
    May 15, 2013 at 5:08 pm
    Thanks for the reply.
    But that’s just plain silly that we’re on version 11 (12 if you count the Controversial Cloud version) and there’s an attribute that just doesn’t work.
  • Todd Kopriva
    May 15, 2013 at 11:15 pm
    You can submit a bug report to make sure that something like this gets in the queue to be fixed:
    https://www.adobe.com/go/wish
    After Effects team blog
