Activity Forums Zaxwerks Duration animation Problems
  • Duration animation Problems
    Posted by Jose Luis martinat on August 8, 2007 at 6:01 am
    I’m working for the first time with proanimator. Working in after affects. I’m working with a long animation. My problem is that i can not make the duration of the animation longer than 30 secs (i’m not able to type in a new duration in the animation window). When i use the proaniamtor jus by itself (not with AE) it is posible to type in a new duration . Why?…. I’m working with sound so i need to be able to work through after effects. I’m just a beginner…. thanks for any help.
    best
    Jose
    Jose Luis martinat replied 19 years ago 2 Members · 2 Replies
  • Serge Hamad
    August 8, 2007 at 5:02 pm
    -Make sure that the duration of your composition is as long as needed.
    -In the AE timeline your Proanimator layer should have the same length
    -The Proanimator Animation timeline should then adjust automatically.
    Salut.
    Serge
    INVIGORATOR-TRAINING VOL.1 soon available here: https://www.nyc-visual.com
  • Jose Luis martinat
    August 10, 2007 at 7:55 am
    Thank you so much for the help. It worked! I’m just a begginer
    Best,
    Jose
