Duplicating Video Fx
Posted by Mark Prebonich on May 18, 2011 at 7:46 pmI have 2 events on the timeline that I would like to work with. I have added the warm color corrector to the first event and then adjusted the settings in the pop up window to make it not quite as warm. Am I able to put the same settings as the first event onto the second event so I do not have to retweak the pop up window, which I would not be able to perfectly duplicate? Thanks.
-Mark
Nigel O’neill replied 15 years, 4 months ago 4 Members · 7 Replies -
Daniel Hughes
May 18, 2011 at 8:16 pmAbsolutely!
When your corrections are set, you can save it as a preset by typing a name you wish to call it and saving.
You can now access these same settings in the Video FX Tab, to click and drag:
Or load the settings in the colour correction plugin’s drop down list:
Hope this helps!
Daniel Hughes
Amateur Writer, Director,
Director of Photography
United Kingdom -
Mark Prebonich
May 18, 2011 at 11:10 pmThat was a great help. Thanks for taking the time to respond. I am amazed at how some people such as yourself make things so easy to understand. Very much appreciated.
-Mark
Daniel Hughes
May 19, 2011 at 12:00 amWell that’s very nice haha!
I’m glad I could help 🙂Daniel Hughes
United Kingdom -
Nigel O’neill
May 19, 2011 at 4:01 amHow about selecting ‘copy’ on the source event and then selecting ‘paste event attributes’ on the target event?
Intel i7 920, 12GB RAM, ASUS P6T, Vegas Pro 10 (x32/x64), Windows 7 x64 Ultimate, Vegas Production Assistant 1.0, VASST Ultimate S Pro 4.1, Neat Video Pro 2.6
Daniel Hughes
May 19, 2011 at 4:18 pm@Nigel nice! I’ll have to remember that one 🙂
Daniel Hughes
United Kingdom -
Matt Crowley
May 19, 2011 at 7:10 pmWatch out when using Paste Event Attributes though – you end up pasting more than the effects. Pan/Crop, the event switches and maybe more also get applied to the clip you paste to.
It’s probably better to save the FX as a preset and apply that to other events. If you have multiple FX that you want to copy, save them as an FX package (Save As on the plugin chooser window).
Nigel O’neill
May 20, 2011 at 3:17 am@Matt – yes, correct, thanks for pointing that out.
