Activity Forums Avid Media Composer Duplicating sequence sync issue
  • Duplicating sequence sync issue
    Posted by Paul Allen on August 17, 2010 at 7:41 pm
    Hi All,
    Having a weird thing happening here. When I duplicate a sequence, the new sequence is out of sync – even though the old one was in sync. It’s the same problem this person was having (https://community.avid.com/forums/p/82112/459857.aspx)- but no-one came up with a solution as far as I can see on the Avid forum.
    Any ideas? It’s pretty weird.
    Paul
    Avid Media Composer. PC with Intel DP35DP s775 iP35 ATX motherboard. Core 2 Extreme CPU QX6800 2.93GHz (4 CPUSs). 2030MB RAM. 256MB Nvidia Quadro/FX1500 PCIe
    Paul Allen replied 16 years, 1 month ago 1 Member · 1 Reply
  • Paul Allen
    August 18, 2010 at 9:18 pm
    Just in case anyone is having a similar problem, I’ve found the solution…
    Basically I had fades or disolves which crossed over each other – Avid was somehow interpretting this as requiring extra frames, thus putting it out of sync. If anyone is having problems look at your disolves and work from there – if you remove the effect then it will hopefully solve the problem.
