Activity Forums Adobe After Effects Duplicating keyframes isn’t working, and I can’t figure out why
  • Duplicating keyframes isn’t working, and I can’t figure out why
    Posted by Ty Flowers on April 6, 2012 at 4:45 pm
    I’m using AE 5.5 on a Mac G5 tower running Lion. I’ve found that when I try to hold a keyframe in place for a few seconds — So, if I want the position to STAY PUT for a few seconds, I do this by copying the keyframe and then pasting it 2 seconds later in the composition. So, this should mean to me that the position shouldn’t change. However, I’ve noticed that while the position does return to its original location once it reaches this second keyframe, in between this time the position will vary widely. I’ve noticed that this happens whether I’m using Easy Ease or not. The only solution I’ve found is to copy the original keyframe and paste it on EVERY SINGLE FRAME until it reaches the point at which I want it to stop holding place.
    There must be something I’m missing. Has anyone else experienced this?
    Ty Flowers replied 14 years, 5 months ago 2 Members · 2 Replies
  • John Cuevas
    April 6, 2012 at 5:11 pm
    Your keyframe interpolation is set to bezier or continous bezier and you want linear keyframes. Highlight all your keyframes and right click on them and select keyframe interpretation and change spatial and temporal to linear.
    Keyframe interpolation
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
  • Ty Flowers
    April 6, 2012 at 5:22 pm
    Yep, that sounds like a complete solution. Thanks!
