Activity Forums Adobe After Effects Duplicating frames problem when footage imported
  • Duplicating frames problem when footage imported
    Posted by Hannah1979 on June 6, 2007 at 3:29 am
    hi wondering if someone could help me..
    im importing mpeg files that i captured using premiere pro 2 when i put the clips into after effects they seem to be duplicating about 3 frames in certain parts of the foootage giving it a jerky look.. i have viewed the raw footage and there is no duplication only in after effects..
    i have also tried starting all over with a new project file and the footage still duplicates in exactly the same places .. it does this with nearly every file i am importing to after effects..
    PLease help>>>??
    Hannah1979 replied 19 years, 3 months ago 2 Members · 2 Replies
  • Steve Roberts
    June 6, 2007 at 9:34 am
    Can you open the MPEG in Quicktime Pro and export to a different codec, such as Photo-JPEG, Animation or an uncompressed 8-bit codec?
    AE may not like MPEG, since that is a delivery codec, and AE prefers higher-quality, lower-compression intermediate codecs like the ones I mentioned.
  • Hannah1979
    June 16, 2007 at 6:16 am
    guys thanks so much.. so simple!! thanks again.. problem fixed!!
