Activity Forums Adobe After Effects Duplicating comps…
  • Duplicating comps…
    Posted by Steve Blacker on December 2, 2009 at 4:28 pm
    Quick question…
    I have a project containing a comp, which in turn contains many precomps. I am creating different versions of the main comp, and so duplicating it (and the precomps inside it) to create these different versions.
    My question is: is there a way to duplicate a comp that will automatically create duplicates of all the precomps inside it?
    Steve
    It’s only work if you’d rather be doing something else…
    Steve Blacker replied 16 years, 9 months ago 4 Members · 4 Replies
  • John Mecklenborg
    December 2, 2009 at 4:52 pm
    I believe EDIT>DUPLICATE should do the trick.
  • Chris Wright
    December 2, 2009 at 7:17 pm
    I believe importing the project compositions back into the project should retain the proper linking.
    https://technicolorsoftware.hostzi.com/
  • Curious Turtle
    December 2, 2009 at 7:52 pm
    Chris is 100% right. I’ll often create little “snippet” projects that I can just import and adjust as necessary without affecting the original precomp. So give that a try.
    Cheers,
    Ben
    Curious Turtle Pro Video
    Training | Editing | Support
    Out Now – Film Wash Color Effects Vol. 3
    & Mocha training for AE & FCP
  • Steve Blacker
    December 2, 2009 at 11:57 pm
    Thanks for the responses, guys. I was afraid the answer was no… It would be a handy feature for sure. I will definitely try the other method of importing the project. Thanks again.
