Activity Forums Adobe After Effects Duplicating Comps WITH Precomps?
  • Duplicating Comps WITH Precomps?
    Posted by Ben Insler on September 22, 2011 at 8:30 pm
    Hey COW!
    Is this possible? Is there a way to duplicate a comp along with all the precomps inside of it, to create a new editable set of comps that does not relink back to the original final comp? For example. Comp A contains Comps B and C. Can I duplicate A to create A-1, and also have AFX automatically duplicate B and C inside of A, creating B-1 and C-1 already placed in A-1 for me? This way I can make changes in B-1 and these changes will only show in A-1, not A. Right now I have to duplicate all comps and swap out every precomp. Very painful.
    Ben
    Ben G unguren replied 14 years, 11 months ago 4 Members · 3 Replies
  • Walter Soyka
    September 22, 2011 at 8:58 pm
    See Brennan Chapman’s True Comp Duplicator script [link].
    Walter Soyka
  • Jason Brown
    September 22, 2011 at 10:14 pm
    This is amazing! I just did a project that could have totally benefitted from this.
    Thanks for sharing Walter!!! 🙂
  • Ben G unguren
    September 23, 2011 at 12:02 am
    Here’s an old-school way to do this, probably defunct with the script Walter offered:
    Make a copy of your AE project, select your comp that you want to duplicate and choose “Reduce Project” -(This deletes everything in your project except whatever is needed for that particular composition, including precomps.)
    Save your reduced project.
    Reopen the main project file, and import your reduced project. You can do this as many times as you need to — with each import all the other comps will be re-imported and arranged properly.
    Once you’re done importing, you can choose “File–>Consolidate footage…” which will take care of any duplicated assets.
    Ben Unguren
    Motion Graphics & Editing
    http://www.mostlydocumentary.com
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
