Activity Forums Adobe After Effects Duplicating and rotating an object in increments around a central point
  • Duplicating and rotating an object in increments around a central point
    Posted by Joey Campbell on January 16, 2013 at 11:08 pm
    Hi I’ve created a ‘rising sun’ type image in after effects and my plan was to import all of the sunbeam paths from illustrator into after effects and then replace the illustrator beam with an individual animated beam. I don’t think this will work as all of the illustrator beams will be imported as separate objects.
    As a plan B – is it possible to copy and paste layers in AFX so as each time the layer is duplicated it rotates and moves slightly forming a circular pattern ? (I’ve tried doing the same way as you would in illustrator – by alt clicking on the rotate pivot point you can duplicate an image around itself in steps).
    Any help would be great
    Vishesh Arora replied 13 years, 7 months ago 2 Members · 3 Replies
