Activity › Forums › Adobe After Effects › Duplicating a comp and its sub comps.
  • Duplicating a comp and its sub comps.
    Posted by Kit Carson on July 19, 2016 at 1:02 pm
    I have a sub composition which I have duplicated into another ‘main’ composition.
    I want to be able to duplicate the main sub comp but also see what it looks like in the main comp also.
    What I really want to be able to do is duplicate the entire comp with all the sub comps in it, so I can see the different versions however when I duplicate the main comp it is still linked to the original sub comp. Whats the best way around this?
    Kit Carson replied 10 years, 1 month ago 2 Members · 2 Replies
  • Walter Soyka
    July 19, 2016 at 1:30 pm
    Two options:
    1) True Comp Duplicator: https://aescripts.com/true-comp-duplicator/
    2) File > Save As…, and choose a new filename for your AEP. Select the comp you wish to duplicate, and with that selection choose File > Dependencies > Reduce project. This will remove everything from your project except the comp you selected and the items upon which it depends. Re-open your original AEP, then import the new reduced AEP to get the independent comp/precomp structure. You can re-import as many independent copies as you’d like.
    Walter Soyka
    @keenlive   |   RenderBreak [blog]   |   Profile [LinkedIn]
  • Kit Carson
    July 20, 2016 at 8:12 am
    Perfect thanks!!
